AAR settings
Mar 6th, 2008
I`ve configured AAR so that phone A has been allocated AAR GRP A, Phone B AAR Group B
Phone A MASK 441615551000 AAR Group A, Location A, AAR CSS full access
Phone B MASK 12125551000 AAR Group B, Location B, AAR CSS full access
To dial Phone B from A I dial Telco 90012125551000 so due to this I have created an AAR group B with 900 in the Dial prefix to A
Testing
I modified the Location setting of B to 1KBP so to force AAR in place but when I make the call I get "Call can not take place ....." Is it the location B which is Allocated to B or do I reduce A ?
The only other part is that I use site codes to call A to B but with AAR if the call fails due to BW then it replaces the site code with the Mask ?
Any Idea`s
Jaime Valencia Thu, 03/06/2008 - 10:30
have you enabled AAR thru the parameters?
does the GW is also part of the AAR group?
the number that AAR will dial is going to be the AAR prefix + external phone number mask.
that number needs to be routable thru the PSTN
javalenc
iptuser55 Fri, 03/07/2008 - 07:45
Thanks for the reply, The GW has the same AAR group as Phone A i.e. it inserts 900 to the external mask- same as the phone. AAR is set to true as well
