IMA Error
Mar 6th, 2008
From ima interface output, there is many Ne Failure errors keep increasing, in the meanwhile, I observe that the Tx cells shows negative figure (-806656510), the Rx cells is positive figure (655927588), may I know why it like this? Thank you!
USROUTER1#sh ima int atm0/ima0
Interface ATM0/IMA0 is up
Group index is 12
Ne state is operational, failure status is noFailure
IMA Group Current Configuration:
Tx/Rx minimum required links 1/1
Maximum allowed diff delay is 60ms, Tx frame length 128
Ne Tx clock mode ITC
Test pattern procedure is disabled
IMA Group Total Counters (time elapsed 1945321 seconds):
-806656510 Tx cells, 655927588 Rx cells
13146 Ne Failures, 5418 Fe Failures, 29317 Unavail Secs
IMA link Information:
Link Physical Status NearEnd Rx Status Test Status
ATM0/0 up active disabled
ATM0/1 up active disabled
USROUTER1#sh controll atm0/ima0
Hardware is ATM AIM IMA connected to AIM slot 1
hwidb=0x648A6F20, sardb=0x648ADB64
slot 0, unit 0, subunit 1
MXT5100 versions: Framework 0x3380, Utils 0x3380,
AAL5 0x3380, AAL2 0x3380, AAL1 0x3380,
IMA 0x3380, CS 0x3380, Frame 0x3380.
Current (mxt5100_t)sardb:
Ind_Q(0xFA94960), Ind_Q_idx(885), Ind_Q_size(30000)
Cmd_Q(0xFA8FB00), Cmd_Q_idx(863), Cmd_Q_size(20000)
Inpool(0xFA59080), Inpool_size(4096)
Outpool(0xFA5A0C0), Outpool_size(4096)
Localpool(0xFA60000), Localpool_size(256)
StorBlk(0xF8E5000), host_blk(0xF8E40C0), em_blk(0xF8E4180)
tx_buf_desc(0xFA88A80), tx_free_desc_idx (1023)
MXT5100 sub_channel_mode is disabled
MXT5100 number of buffers in Inpool: 1024, Outpool 0
FPGA revision 0x2070007
MXT5100 IMA Group Info:
Group Number (0), Group Port ID (0x1005)
Group Index (0), Group Open Status SUCCESS
VCs configured (1)
IMA group alarms: NONE
IMA Link(0) alarms: NONE
IMA Link(1) alarms: NONE
MXT5100 Channel Info:
Channel Info (0):
Chan_ID (0x1225), Open Status SUCCESS, VC(1)VPI/VCI(5/32),
Tx SBD(used/max 1/40) , Tx PDU(443288966), Tx PDU discard(0)
Tx SDU size err(0), Tx cell CLP0(103820077), Tx cell CLP1(0)
Rx PDU(489459862), Rx PDU discard(0), Rx SDU size err(785746)
Rx CRC err(10673345), Rx cell CLP0(-574383716), Rx cell CLP1(0)
Thank You,
Trina
paolo bevilacqua Thu, 03/06/2008 - 06:00
  • Hall of Fame,
    Founding Member
That is classical case of signed counter overflow, nothing to worry about. If you upgrade IOS, chances are it will go away.
trinawong Thu, 03/06/2008 - 06:50
Thank you for your update.
From the output can see many errors when do 'show controller atm0/ima0', telco tested many times that informed layer1 is no problem, could you advise what could be the problem here. Thank you.
Channel Info (0):
Chan_ID (0x1225), Open Status SUCCESS, VC(1)VPI/VCI(1/100),
Tx SBD(used/max 3/40) , Tx PDU(11887897), Tx PDU discard(0)
Tx SDU size err(0), Tx cell CLP0(130838239), Tx cell CLP1(0)
Rx PDU(12754220), Rx PDU discard(0), Rx SDU size err(3)
Rx CRC err(79), Rx cell CLP0(214830840), Rx cell CLP1(0)
Configuration:
USROUTER1#sh run int atm0/ima0
Building configuration...
Current configuration : 216 bytes
interface ATM0/IMA0
mtu 1500
bandwidth 4096
no ip address
ip flow ingress
ip route-cache flow
carrier-delay msec 100
ima clock-mode independent
ima differential-delay-maximum 60
no atm ilmi-keepalive
end
USROUTER1#sh run int atm0/ima0.1
Current configuration : 1027 bytes
interface ATM0/IMA0.1 point-to-point
bandwidth 2452
ip address X.X.X.X X.X.X.X
ip access-group CISCO-SECURITY in
rate-limit output access-group 178 8000 8000 8000 conform-action set-dscp-transmit 48 exceed-action set-dscp-transmit 48
rate-limit output access-group 179 8000 8000 8000 conform-action transmit exceed-action transmit
rate-limit output access-group 180 16000 8000 8000 conform-action set-dscp-transmit 16 exceed-action set-dscp-transmit 16
rate-limit output access-group 182 256000 32000 32000 conform-action set-dscp-transmit 26 exceed-action set-dscp-transmit 28
rate-limit output access-group 184 2048000 256000 256000 conform-action set-dscp-transmit 0 exceed-action set-dscp-transmit 0
ip mroute-cache
pvc 1/100
class-vc VcClass_0
vbr-nrt 3648 3648 1
oam-pvc manage
oam ais-rdi 15 3
encapsulation aal5snap
transmit-priority 3
max-reserved-bandwidth 100
service-policy output atm_output
end
USROUTER1#sh run int atm0/1/0
Current configuration : 132 bytes
interface ATM0/1/0
mtu 1500
no ip address
scrambling-payload
ima-group 0
end
USROUTER1#
USROUTER1#sh run int atm0/1/1
interface ATM0/1/1
mtu 1500
no ip address
scrambling-payload
ima-group 0
end
paolo bevilacqua Thu, 03/06/2008 - 13:50
  • Hall of Fame,
    Founding Member
Which errors are referring to? if the crc, the percentage is negligible respect to the input counter.
