ACE 4710 Appliance GUI configuration
Mar 6th, 2008
I am having an issue with configuration of the GUI for the 4710. If I am using local authentication, the GUI works fine. However when I turn on aaa and use radius to authenticate, I am unable to log into the GUI.
When I place the 4710 into debug for aaa, I am sucessfully authenticating. My radius server's logs state the same.
Has anyone run across this?
Kristopher Martinez Thu, 03/06/2008 - 08:56
  • Cisco Employee,
Are you able to login to the CLI using AAA? Have you configued the role and domain for the user on your AAA server? Here is some documenation on configuring the role and domain for a use on the AAA server:
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA1_7_/configuration/security/guide/aaa.html#wp1321891
codycook70 Thu, 03/06/2008 - 10:31
Yes to both questions. I can see the proper credentials being passed when I put the ACE into debug and the radius server shows a sucessful authentication.
One other item to note, any local accounts work fine, those that are being authenticated via radius are not.
