dynamic ipsec between a statically addressed pix and dynamically addressed
Mar 6th, 2008
above is currently the URL I am using. Both ends of the VPN are config'd as per document apart from IP details.
On the router side I am using a Cisco 1841 with a HWIC-3G-GSM card. This connects onto the Vodafone 3G network and is assigned a private IP address. This then NATS onto a Public IP address.
The remote device we are using is a PIX firewall version 6.3. This device needs to be able to accept VPN connections from any IP address.
Phase 1 on the VPN is coming up fine but I am not seeing any traffic on phase 2. Packets are being encrypted but not decrypted at both ends of the VPN.
dst src state conn-id slot status
80.x.x.x 10.x.x.x
sh crypto ipsec sa
interface: Cellular0/0/0
Crypto map tag: to_vpn, local addr 10.x.x.x
protected vrf: (none)
local ident (addr/mask/prot/port): (
remote ident (addr/mask/prot/port): (
current_peer 80.x.x.x port 500
PERMIT, flags={origin_is_acl,}
#pkts encaps: 9830, #pkts encrypt: 9830, #pkts digest: 9830
#pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
Packets are being encrypted but not being decrypted.
Any help would be greatly appreciated
kevin-howell Fri, 03/07/2008 - 06:41
The issue is now resolved. Seem to be a PIX config issue.I received a technical guide outlining all changes on the devices
