ASA 5510 ssh
Mar 6th, 2008
i have router 2801 which is connected to ASA to Outside interface, and have problem with ssh ver 1.
sh ssh Inside Outside.
any suggestions?
brettmilborrow Thu, 03/06/2008 - 08:06
have you generated your ssh keys on the ASA?
Try this command:
crypto key generate rsa modulus 1024
aadilovic Thu, 03/06/2008 - 08:33
yes i do...
and security-level on out interface is 50
from inside its work
brettmilborrow Thu, 03/06/2008 - 08:37
try running:
'debug ssh'
And then attempt to connect to the firewall using ssh. This may give a clue why the session is failing.
aadilovic Fri, 03/07/2008 - 06:23
when i try to connect i get this on router
2801#ssh -v 1 -l local
[Connection to aborted: error status 33]
brettmilborrow Fri, 03/07/2008 - 15:42
Could you run the 'debug ssh' command on the firewall whilst you try to connect.
dylan.webb Wed, 10/16/2013 - 19:34
I had a similar problem with an ASA5510 (
Switch#ssh -l admin
[Connection to aborted: error status 34]
after generating a new cert and changing ssh ver to 2 the problem disapeared.
Not sure if this is an option for you but I know there are some vulnerabilitys in ssh v1 as well.
Julio Carvajal Wed, 10/16/2013 - 21:49
Hello Dylan,
Remember that SSH version 1 uses 768 bits for the rsa key
ssh -v 1 -l username  IP address
Make sure you have configured the ASA to use Version 1
ASA(config)# ssh version 1
