Blocked traffic flow..
I get the same results pinging in eiter direction through the VPN tunnel (tunnel is working fine) below is a trace and included is the config.
HO1ASA02# packet-trace input inside icmp 10.1.6.121 3 1 10.60.50.1
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Additional Information:
Found no matching flow, creating a new flow
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in 0.0.0.0 0.0.0.0 Outside
Phase: 3
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in 10.1.0.0 255.255.240.0 Inside
Phase: 4
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group Inside_access_in in interface Inside
access-list Inside_access_in extended permit ip object-group IT_DEPT any
object-group network IT_DEPT
description: IT IP Address Group 10.1.6.0/24
network-object 10.1.6.0 255.255.255.0
network-object host 10.1.7.166
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect icmp
service-policy global_policy global
Phase: 7
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
Phase: 8
Type: IDS
Subtype:
Result: ALLOW
Config:
Phase: 9
Type: NAT-EXEMPT
Subtype:
Result: ALLOW
Config:
nat (Inside) 0 access-list nat0
nat-control
match ip Inside any Outside 10.60.50.0 255.255.255.0
NAT exempt
translate_hits = 6, untranslate_hits = 200
Phase: 10
Type: NAT
Subtype:
Result: ALLOW
Config:
nat (Inside) 1 0.0.0.0 0.0.0.0
nat-control
match ip Inside any Outside any
dynamic translation to pool 1 (*.*.*.70)
translate_hits = 0, untranslate_hits = 0
Phase: 11
Type: NAT
Subtype: host-limits
Result: ALLOW
Config:
nat-control
dynamic translation to pool 1 (63.85.131.70)
Phase: 12
Type: VPN
Subtype: encrypt
Result: ALLOW
Config:
Result:
input-interface: Inside
input-status: up
input-line-status: up
output-interface: Inside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
brettmilborrow Thu, 03/06/2008 - 08:30
Your routing is not configured correctly:
Result:
Check that you have reverse-route configured on your crypto map entry, or manually add the routes your firewall.
