CSA 4.5 Multiple Domains
Mar 6th, 2008
Currently our company is in the process of a merger which will require 2 separate domains to be run at the same time.
My question is can we set up the CSA server to run for both domains? Is there a way for CSA clients on both domains to report and be controlled by the same central CSA server?
Thanks in advance for your help.
Overall Rating: 5 (1 ratings)
tsteger1 Fri, 03/07/2008 - 10:44
  • Red, 2250 points or more
The answer to your questions is yes. CSA only requires the agent be able to resolve the MC using DNS (or WINS).
How you proceed depends on several things.
Do all hosts have CSA installed now?
Tom
adammuthard Mon, 03/10/2008 - 09:40
That's great news. Thanks for the heads up.
Currently only 1/2 of the company has CSA installed now. The other 1/2 (new half as of the merger) will have CSA installed at a later date.
