Unity Express VMail passwords
Answered Question
Mar 6th, 2008
Is it possible to configure Unity express to not require passwords. I know that when you first set up users, you can give a blank password initially. but when the user enrols, it makes you set a password. Is there a way to set the system so that it is not compulsory for users to set a password when they enrol.
Correct Answer by Rob Huffman about 9 years 4 months ago
Hi David,
This is not possible my friend.
User Interfaces/Passwords
Cisco Unity Express R1 has three separate user interfaces: a GUI, CLI and TUI (subscriber telephony interface). There are two types of users: administrators and end users (subscribers). Administrators can have access to the GUI and the CLI; subscribers can have access to the GUI and TUI.
The GUI and CLI login protections are referred to as a "password", while TUI login protection is referred to as a "PIN".
GUI
All User IDs defined on the system are password controlled on login, regardless of whether the User ID has administrator or subscribers privileges. Passwords are **mandatory and are 3 to 32 characters long, case sensitive, and allow alphabetic and numeric characters.
TUI
All mailboxes defined on the system are PIN controlled on login. PINs are **mandatory, are 3 to 19 characters long, and allow numeric characters.
From this good CUE Security doc;
http://www.cisco.com/en/US/netsol/ns340/ns394/ns165/ns391/networking_solutions_design_guidance09186a00801f8e31.html#wp41238
When the password is left blank in the initial config, CUE marks it as expired and forces the user to set one.
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Thu, 03/06/2008 - 13:47
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi David,
GUI
TUI
Hope this helps!
Rob
silex Thu, 03/06/2008 - 13:57
many thanks Rob,
exactly what I was looking for.
Rob Huffman Thu, 03/06/2008 - 14:09
  • Hall of Fame,
    Founding Member
Hi David,
You are most welcome :)
Cheers!
Rob
