CRC error checking on interface
Mar 6th, 2008
Is is possible to disable CRC error checking on any type of interface ? If possible what is the command for it. I know that I can configure crc 32 and crc 16 on interface. But can I stop crc error checking on an interface ?
thiru.vel10 Thu, 03/06/2008 - 11:24
To disable the 32-bit CRC and return the interface to the default 16-bit CRC, enter the no crc 32 command.
Ex,
Router(config)# interface pos 7/1
Router(config-if)#no crc 32
paolo bevilacqua Thu, 03/06/2008 - 13:46
  • Hall of Fame,
    Founding Member
No you can't, because crc is part of the transmission standards, and if you was to ignore crc, you would accept potentially corrupted data, with unpredictable consequences.
cisco_query Thu, 03/06/2008 - 22:45
crc 32 or crc 16 which will detect more transmission errors ?
paolo bevilacqua Fri, 03/07/2008 - 01:25
  • Hall of Fame,
    Founding Member
crc 32 is a more robust and better error detection code.
hope this helps, please rate post if it does!
