Unity Connection import users template error
tahequivoice
Level 2
Level 2
Just built a UC2.1 server and after integrating it with the callmanager, I tried to import the users, and I get a "No user templates were found for the selected phone system" error. I went through everything and could not find a problem, the templates are showing the server etc. Where do I go from here?
Tray Stoutmeyer
I have seen this issue once before. Try the following.
In my case, the problem actually was that UC stores search/find
information in cookies such that it remembers the users last search, Occasionally it
happens that something gets stuck that collides with another field of the same name.
Clearing the cache and temp from the browser option helped resolving the issue.
Hope this helps you.
Tray
Tray Stoutmeyer
Tray
That did it. I cant believe it was something as simple as that, and here I was about to rebuild the stupid thing thinking something was messed up in the code. Thanks, you saved me a great deal of time.
You are very welcome. Glad it saved you a real headache.
Tray
