Prompt, Delay, Prompt
Mar 6th, 2008
Hi There !
I'd like to play a prompt_A only for 30s, then play another prompt_B.. then come back playing prompt_A from where it stopped...
is it possible ?
Other option would be to play prompt_A for 30s, play prompt_B and start playing prompt_A again from start.
Thanks.
Andrei.
Riccardo Bua Fri, 03/07/2008 - 01:48
  • Cisco Employee,
Hi Andrei,
the easier way would be to split prompt_A in a Prompt_A of 30s and a second Prompt_C of the remaining, hence allowing you to play Prompt_A whenever you need.
There isn't any media manipulation you could do on prompts AFAIK.
Riccardo
