ASA 5505 config help
Mar 6th, 2008
I will like to configure inside/outside interfaces on the ASA 5505 as you see on the attached file can you help.
I configure so far
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address 192.168.10.1 255.255.255.248
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
and get dhcp/static to work when I connect directly to the ASA but did not see any when I connect it thru mini-hub or switch. I appriciate your help
jojuarez Sat, 03/08/2008 - 20:23
If communication works fine when directly connected, it's not an ASA issue. Other than ethernet settings, there's nothing else you can configure for that particular issue
