03-06-2008
10:34 AM
- last edited on
02-21-2020
11:47 PM
by
cc_security_adm
Is there a way to do Spoke-to-Spoke Direct Communication using Easy VPN client at the remote sites? I've searched all over and can't find any good examples. I'm using ASA's at all locations.
Thanx,
-Tim
03-12-2008 01:32 PM
Spoke-Spoke VPN can be accomplished between ASAs. Refer to URL http://cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00804675ac.shtml for more information.
05-22-2008 09:48 AM
Hi Tim,
I have been searching for same thing. The only feature that allows spoke to spoke would be DMVPN but that is not yet supported on ASA models, only some version of routers.But no using EasyVPN.
05-22-2008 09:54 AM
Actually, I got it working without DMVPN. You have to use at least 8.0(3)(I think) and do
same-security-traffic permit intra-interface
That enables the capability, then you just need to worry about the translations and routing between the networks.
-Tim
07-10-2013 09:04 AM
Hi Tim,
Can you help how it will be possible ?
Can you give example for translations and routing?
I am new to Easy VPN and any IPsec VPN.
You can refr my post :
https://supportforums.cisco.com/thread/2227552?tstart=0
