Direct Transfer to Voice Mail on a phone that is forwarded
Answered Question
Mar 6th, 2008
This may be an order of operation type issue but Im not sure.
We have a user who has their phone forwarded to an internal extension. When the receptionist tries to use the attendent console to transfer a call directly to that persons voice mail the option is greyed out and they cannont place any calls into that users voice mail
Im pretty sure this simply comes from the fact that the users phone is forwarded. Id like to know if there is a way around this short of adding a second extension to the phone to handle voice mails when the phone is forwarded.
Thanks for any insights,
Correct Answer by Brandon Buffin about 8 years 7 months ago
Create a CTI route point to send callers directly to a user's voicemail using * plus the extension. I'm assuming you're using CCM and Unity. Take a look at the following link.
Hope this helps. If so, please rate the post.
Overall Rating: 5 (1 ratings)
charnsrobert Thu, 03/06/2008 - 11:04
Thanks much for the info. I've started looking into the CTI route point and that looks to be the ticket.
Thanks again!
