ASA Dual ISP - VPN L2L?
I have an asa cluster where L2L Tunnels are configured.
Now i want to have an Backup ISP at the ASA side.
What i have done is SLA Monitoring for the ISP backup if the primary ISP fails.
But how can i cant the crypto map to the "backup interface" i think that it is not possible to have the same crypto map on 2 interfaces.
I found much about this question in netpro, but not really a solution.
regards
Bernhard
schannro
Hello!
I have the same issue but the swap from the primary to the backup works well, but the swap form the backup to the primary is a problem because I have to active SAs with the same cryptodomain and that's why the the asa don't know which SAs should take it.
Here a configuration output:
crypto map outside1_map 1 match address outside1_1_cryptomap
crypto map outside1_map 1 set peer 1.1.1.1 2.2.2.2
crypto map outside1_map 1 set transform-set ESP-3DES-SHA
crypto map outside1_map 1 set security-association lifetime seconds 28800
crypto map outside1_map 1 set security-association lifetime kilobytes 4608000
crypto map outside1_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside1_map interface outside1
crypto map outside2_map 1 match address outside2_1_cryptomap
crypto map outside2_map 1 set peer 2.2.2.2 1.1.1.1
crypto map outside2_map 1 set transform-set ESP-3DES-SHA
crypto map outside2_map 1 set security-association lifetime seconds 28800
crypto map outside2_map 1 set security-association lifetime kilobytes 4608000
crypto map outside2_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside2_map interface outside2
tunnel-group 1.1.1.1 type ipsec-l2l
tunnel-group 1.1.1.1 ipsec-attributes
pre-shared-key *
isakmp keepalive threshold 10 retry 3
tunnel-group 2.2.2.2 type ipsec-l2l
tunnel-group 2.2.2.2 ipsec-attributes
pre-shared-key *
mfg
schannro
janakamolagoda
Hi Bernahard,
Have found any solution to this ? I am facing the same issue,
Janaka
