Nat problems?
Mar 6th, 2008
Hi all,
I have a problem with a router cisco 837 on my work. That is the configuration:
1 DSL Wan Interface named ATM0.1 with the external ip Ex: 80.36.25.24 and NAT outside, and the ethernet interface with internal ip ex: 172.26.0.254 and NAT inside.
The nat config is:
ip nat inside source list 102 interface ATM0.1 overload
ip nat inside source static tcp 172.26.0.1 8081 interface ATM0.1 8081
That's work fine if i try to connect with my browser from the external(ex: my house) to my work to the port 8081.
But, doesn`t work if i try to connect from my computer in the office using my external ip and port on the browser. URL ex: http://80.36.25.24:8081. My computer have the ip 172.26.0.53.
Wich are the correct configuration for that work correctly??
lamav Thu, 03/06/2008 - 12:03
  • Blue, 1500 points or more
Can you post the entire config?
alfil2k08 Thu, 03/06/2008 - 12:20
Yes, this is the conf
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname C837
logging queue-limit 100
no logging buffered
ip subnet-zero
ip name-server 80.58.61.250
ip name-server 80.58.61.254
ip dhcp excluded-address 192.168.1.1
ip dhcp pool CLIENT
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 80.58.61.250 80.58.61.254
lease 4
ip audit notify log
ip audit po max-events 100
no ftp-server write-enable
interface Ethernet0
ip address 172.30.29.254 255.255.255.0 secondary
ip access-group 103 in
ip nat inside
ip tcp adjust-mss 1452
hold-queue 100 out
no sh
interface ATM0
no ip address
no ip route-cache
no ip mroute-cache
atm vc-per-vp 256
no atm ilmi-keepalive
dsl operating-mode auto
no sh
interface ATM0.1 point-to-point
ip address 80.36.25.24 255.255.255.128
ip nat outside
no ip route-cache
no ip mroute-cache
no sh
pvc 8/32
encapsulation aal5snap
ip nat inside source static tcp 172.30.29.1 8081 interface ATM0.1 8081
ip classless
ip route 0.0.0.0 0.0.0.0 ATM0.1
no ip http server
no ip http secure-server
access-list 23 permit 172.30.29.0 0.0.0.255
access-list 102 permit ip 192.168.1.0 0.0.0.255 any
access-list 102 permit ip 172.30.29.0 0.0.0.255 any
access-list 103 deny ip 192.168.1.0 0.0.0.255 172.30.29.0 0.0.0.255
access-list 103 permit ip any any
dialer-list 1 protocol ip permit
scheduler max-task-time 5000
end
lamav Thu, 03/06/2008 - 12:38
Two things:
1.) You say the interface address for your ethernet interface is 172.26.0.254, but its not.
interface Ethernet0
ip nat inside
hold-queue 100 out
no sh
2.) If you are on the 172.26.0.0/24 network (you say your PC address is 172.26.0.53), your traffic will not be NAT'ed because ACL 102 is not permitting it.
Victor
alfil2k08 Thu, 03/06/2008 - 13:48
sorry victor, i wrote wrong ip on the original message. the correct segment on lan is 172.30.29.0.
Can you see any solutions?
Many thanks,
lamav Thu, 03/06/2008 - 13:50
Ok, but whats your PC's IP address...
PC>ipconfig
lamav Thu, 03/06/2008 - 18:40
I really dont see anything wrong with this configuration that would prevent you from accessing the Internet.
Are you being NAT'ed?
Do a "sh ip nat trans" and see if youre being translated.
Ill think of other stuff...
Victor
