Need help on CSS
Mar 6th, 2008
Dear Friends. I need a clarification on css. I have phone configured for internation css but my first line in phone is configured as long distance css, will i be able to make internation call from my line?
secondly if my phone is configured as longdistance css but my line is configured as international css, can i make international call from line.
pls clarify
esa
Brandon Buffin Thu, 03/06/2008 - 12:49
  • Purple, 4500 points or more
When you have both a device and a line CSS, the resulting CSS is a combination of the 2. If there is a duplicate partition between the 2 CSSs, the line CSS takes precedence. So, in both of these cases, you would be able to make an international call unless in the case where the line has a long distance CSS, that CSS contains a partition which is assigned to a route pattern that explicitly blocks international calls.
Hope this helps. If so, please rate the post.
Brandon
