Cisco IP Phone with LLDP-MED on Nortel Switch
Mar 6th, 2008
I'm trying to get some insights into the capabilities of running LLDP-MED between a Cisco phone and a Nortel switch. I know 8.3.3 firmware will support LLDP-MED but don't know of any actual deployments.
The most important aspect is whether the Cisco phone will dynamically land on a Voice VLAN on the Nortel Switch (similar to how CDP works).
Does anybody have any experience with this?
gogasca Thu, 03/06/2008 - 12:33
  • Green, 3000 points or more
Which phone model and Nortel switch?
jrhofman Thu, 03/06/2008 - 12:50
This is an RFP response. The phones we will likely propose will be 7942's-7962's.
The Nortel closet switches are 5520's. They do not indicate in the RFP if these switches support LLDP-MED but they do state PoE and QoS support.
I'm going to go research the 5520 right now.
Thanks.
saquib.mkhan Tue, 04/15/2008 - 15:52
Did you ever get the Cisco IP phones working with the Nortel 5520's. Any Configuration is greatly appreciated.
jrhofman Tue, 04/15/2008 - 18:30
Nope, I got no feedback from Cisco or anyone else. We decided not to respond to the RFP.
jguay Wed, 01/05/2011 - 08:37
This is an old post but since the subject is rare I thought I'd answer it.
We've had success getting Cisco IP Phones work on a stack of Nortel/Avaya ERS5520 software version 6.2 using LLDP-MED.  The Cisco phones dynamically get their voice vlan id through LLDP-MED and do their DHCP request on the correct vlan.
