Provide level 7 access to https management
Mar 6th, 2008
I currently have the following config for level 7 access. I just want the level 7 folks to be able to enable/disable ports and to add descriptions to interfaces. It works fine if I SSH to the switch, however, it wants level 15 access for the HTTPS management. Any idea how to enable HTTPS access for the level 7 folks?
privilege exec level 7 show
privilege exec level 7 configure terminal
privilege configure level 7 interface
privilege interface level 7 shutdown
privilege interface level 7 description
Overall Rating: 5 (1 ratings)
Edison Ortiz Sat, 03/08/2008 - 11:52
Hi Jason,
I'm afraid is not possible. In order to access the http files in the router, the user must have a high level authentication.
One way to make simple management for novice users while keeping some kind of privilege security, is by implementing menus in the router.
Jason Fraioli Sat, 03/08/2008 - 18:30
looks like a viable option, although I can't figure out how to associate the menu to a login privilege. Do you have any advice on how to accomplish that? The documentation really doesn't discuss that at all.
Edison Ortiz Sat, 03/08/2008 - 18:42
The menu will be used instead of the login privilege.
The users will be only be able to perform tasks within the menu.
