Change VPN idle timeout with CSM
Mar 6th, 2008
I need some help with CSM and group-policy attributes for a VPN on an ASA-5510. Ultimately I like to change the default VPN idle timeout of 30 minutes on an IPSec point-to-point VPN but I can't see how to do that with CSM.
Any ideas?
jbayuka Wed, 03/12/2008 - 15:27
Security Manager maintains the connection between your client system and the Security Manager server.
If you do not use Security Manager for a period of time, your connection to the server automatically closes. The default timeout period is 120 minutes. You can change or disable the idle timeout.
Refer to Server Connection Status and the Idle Timeout section of the CSM user guide for more information
