Serial Interfaces
Answered Question
Mar 6th, 2008
Hi There;
Can anyone tell me - if I have two serial interfaces on a 2811, do I need to specify that one will be used for RS422 and the other for RS232. If so, what command do I use to do this?
thanks
Correct Answer by Richard Burts about 9 years 2 months ago
Darren
There is generally not any command to identify the type of interface connector. The type of card will determine what kind of connector is supported and when the interface card supports multiple connector type there is logic within the interface to check which pins are activated in the connector and determine the type of connector automatically.
Rick
Overall Rating: 5 (1 ratings)
Correct Answer
Richard Burts Sat, 03/08/2008 - 10:58
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Darren
Rick
Richard Burts Mon, 03/10/2008 - 14:51
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Darren
I am glad that my answers were helpful. Thank you for using the rating system to indicate that your question was resolved (and thanks for the rating). It makes the forum more useful when people can read a question and can know that they will read responses which successfully resolved the question.
The forum is an excellent place to learn about Cisco networking. I encourage you to continue your participation in the forum.
Rick
