PIX 506E configuration question
Mar 6th, 2008
I have a pix connected to 2 remote sites (1 & 2 vpn 3000 concentrator on both end sites) I would like to configure the PIX having a principal server (site 1)and a secondary server (site 2)in case principal tunnel fails the second become active
If posible to have this kind of config on a PIX 506E?
Thanks a lot
Jon Marshall Thu, 03/06/2008 - 19:58
Yes you can have 2 entries under your crypto map statement ie.
crypto map vpnset 1 ispec-isakmp
crypto map vpnset 1 set peer "site 1 vpn3000 ip address"
crypto map vpnset 1 set peer "site 2 vpn3000 ip address"
The pix will use the 2nd site vpn 3000 if it doesn't get a response from site 1 vpn 3000.
