ASDM 6.0 Configuration Limited after upgrade
Mar 6th, 2008
Hello:
I upgraded my ASA5510 from 7.0 image and ASDM 5.0 to ASA 8.0(3)/ASDM 6.0(3). Before the upgrade I could use the ASDM to configure my device just fine.
After the upgrade the ASDM is stuck in a read-only mode. I get "You are authorized to access only Home and Monitor Views."
I can use the same user ID and PW to connect via SSH just fine and change anything I want.
The issue is just the ASDM thinks I am in a read only mode.
Suggestions?
amritpatek Wed, 03/12/2008 - 15:29
  • Silver, 250 points or more
If your VPN and HTTP login IDs are same this may happen. Check if you have the following commands in config of your ASA
aaa authentication http console LOCAL
aaa authorization command LOCAL
Also make sure that you have atleast one user with full privilege before doing the upgrade.
