B-ACD problem
Mar 6th, 2008
I'm trying to configure the B-acd TCL application. When I dial aa-pilot, from either internal or external call does not connect.
When I do a "show show call application sessions" there is no output. I reloaded router but still no output from this command. It seems that TCL script isn't loading proberly. Does anyone have any suggestions? Below is config. I'm running CME.
dial-peer voice 200 voip
destination-pattern 4500
session target ipv4:
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 301 voip
service aa
incoming called-number 4500
codec g711ulaw
no vad
dial-peer voice 302 pots
service aa
service queue flash:app-b-acd-
param queue-len 20
param number-of-hunt-grps 1
param aa-hunt2 4210
param queue-manager-debugs 1
service aa flash:app-b-acd-aa-
paramspace english index 1
param handoff-string aa
param dial-by-extension-option 3
param operator 4003
paramspace english language en
param max-time-vm-retry 2
param aa-pilot 4500
param max-extension-length 4
paramspace english location flash:
param second-greeting-time 30
param welcome-prompt _bacd_welcome.au
param call-retry-timer 15
param voice-mail 3600
param max-time-call-retry 45
paramspace english prefix en
param service-name queue
Overall Rating: 5 (2 ratings)
Avner Izhar Thu, 03/06/2008 - 22:49
Try to run 'debug voip application script', make a call from the pots side and let us see the output.
Regards, Avner.
UCcomp2007 Fri, 03/07/2008 - 16:14
Debug revealed I did not have Mandatory Voicemail paramater. Once I added, scripts executes fine.
Thanks for the help.
Just looking through your config and the first thing I've noticed is that under the service queue you have defined "param aa-hunt2 4210"
The first aa-hunt should be 1, param aa-hunt1 4210.
When you invoke the "show call application sessions" if the call is progress you will see the application "aa" but generally you will only see the "queue" application running.
