Hunt Groups CCME - 2 Questions
Mar 6th, 2008
Hi all,
Im configuring CCME4.0 for a client and they have a small callcenter type environment.
When a call is directed to their hunt group they want all 6 phones to ring at once. I have achieved this by creating 6 ephone-dn's and overlaying them on all 6 ephones including their unique extension number. The hunt group will list all six numbers.
Problem i'm facing is that they can't logout of the hunt group because the DN's are all shared. Is there a way around this?
config:
ephone 1
button 1o11,40,41,42,43,44,45
ephone 2
button 1o12,40,41,42,43,44,45
ephone-hunt 1 longest-idle
pilot 589
list 579, 580, 581, 582, 583, 584, 585
timeout 5, 5, 5, 5, 5, 5
statistics collect
description Main Hunt
Secondly, is there an easy way for the client to forward a hunt group pilot to another number during lunch times or staff meetings?
Thanks in advance.
Paul.
Overall Rating: 4 (1 ratings)
paolo bevilacqua Fri, 03/07/2008 - 01:39
  • Hall of Fame,
    Founding Member
What you have now is not a proper hunt-group, and as you have noted, you can't log out of lines that are shared and in hunt group.
You could have accomplished the same result, using regular lines in shared/overlay fashion, with cfb to each other. This wat, the forwarded all fucntion can be used normally.
Note that a proper hunt-group with hlog button will present calls to final destination when all user are logged out, making the forward function unnecessary. I suggest you have you customer to try a regular cycling hunt-group, where the phones do not ring all at once.
Anyway if you customer insists that he wants all the phone to ring at once (again thta is not the way professional hunt-groups work), you can try a script that I wrote for the purpose:
http://pbevila.fastmail.fm/public/bcast.tcl
paul_alexander Tue, 03/11/2008 - 20:43
Thanks mate.
I forgot to mention that they were using B-ACD aswell. But either way, I said to them you can have it this way and it works properly or you can just have it your way.
They chose their way.
Customers....
