AS 5350 discovered as Unknown device
Answered Question
Mar 6th, 2008
After device discovery in LMS 2.3, the RAS (AS5350) is shown as an unknown device. Can anyone help me on this .
Thanks and regards
Rajesh
Correct Answer by Joe Clarke about 9 years 3 months ago
Okay, this is an AS5350XM which is not supported until LMS 2.6 SP1. Therefore, you need to upgrade to CS 3.0.6, RME 4.0.6, and Campus 4.0.10 to get support.
Overall Rating: 5 (1 ratings)
Joe Clarke Thu, 03/06/2008 - 21:54
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
There is no LMS 2.3. Please double-check the version, and provide exactly where you see the device showing as unknown.
rajesh1331 Fri, 03/07/2008 - 22:41
hi Clarke
ooops....It is 2.6.that was a typo :)
Actually Iam using LMS 2.6 and VMS 2.3
rgds
Rajesh
Joe Clarke Sat, 03/08/2008 - 07:57
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Are they installed on the same server?
rajesh1331 Sun, 03/09/2008 - 23:22
Hi Clarke,
Both are running on different servers. LMS with Win 2003R2 OS and VMS in Win 2000.
All my 7200, 3500, 2900 series are being discovered properly , but the 5300 devices are being discovered as unknown devices.
rgds
rajesh
Joe Clarke Sun, 03/09/2008 - 23:35
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Okay, good. the two cannot be installed on the same server, and doing so would definitely have messed things up. You still have not said exactly where these 5300 devices are showing as unknown. A screenshot would be helpful.
Correct Answer
Joe Clarke Mon, 03/10/2008 - 09:16
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
