broadcast problem in LAN
Mar 6th, 2008
i am getting unicast ie to my machine only , but when i am trying to do
broadcast,none of pc in network getting broadcast.
my pc ip is
subnet mask
i have given bcast address in my code as
is there any problem in my bcast address?/?
please help...
Jon Marshall Thu, 03/06/2008 - 23:29
Your broadcast address should be
Your network is which means you have 16 class C subnets ->
ajaysahoo Fri, 03/07/2008 - 00:11
i have given bcast ip as
now also i am not getting broadcast.
is there any problem with UDP port?/?
Jon Marshall Fri, 03/07/2008 - 00:24
What exactly are you trying to do and how do you know that you are not receiving any broadcasts ?
ajaysahoo Fri, 03/07/2008 - 01:23
i have a braodcast process which is receiving messeges from some source.Now i have to send these messeges to all front end guys.when i do unicast, i am able to get messeges.
but when i give broadcast ip, no one (including my self) is getting messeges.
my application is running on AIX.
Richard Burts Sat, 03/08/2008 - 09:32
I am still a bit confused about your topology and about your problem. Can you clarify whether the device that is issuing the broadcast is within the subnet and sending broadcast to the subnet or if it is outside the subnet and sending the broadcast.
If the source of the broadcast is outside the subnet then I believe that I understand the problem and can suggest a solution. First lets be clear about some terminology. If a packet is sent from outside the subnet to the subnet broadcast address then this is termed as a directed broadcast. And directed broadcast is not enabled by default in the IOS. There is an interface configuration command ip directed-broadcast. If you configure that command on the interface then it will enable forwarding of directed broadcasts from outside onto the interface and will reach all the devices within the subnet.
