PIX6.3.5, ACS4.1, TACACS Administration EMPTY
Mar 7th, 2008
I have configured authentication and authorization on PIX6.3.5, I use Cisco ACS4.1, but I do not have executed commands in "TACACS administration" log.
Can you help me?
Overall Rating: 3 (2 ratings)
Jagdeep Gambhir Fri, 03/07/2008 - 06:15
Command accounting logs are stroed in tacacs administration logs. Also there is a known issue on ver 4.1.1 and we need to apply patch ACS to fix the issue.
Patch for appliance is available on
Patch name : ACS SE accumulative patch
Patch for acs windows is available on
Patch Name : ACS accumulative patch
Do rate helpful posts
pslavkovsky Fri, 03/07/2008 - 06:44
Thanks, I have patch applied.
It looks like is a problem of PIX configuration, I did not find relevant accounting command for PIX 6.3.5
Jagdeep Gambhir Fri, 03/07/2008 - 07:01
On pix 6.x version aaa accounting for management traffic cannot be configured and only accounting for pass through traffic is supported.
However, aaa accounting for management traffic as well as pass through traffic is supported on pix 7.x.
pemasirid Wed, 03/12/2008 - 06:50
Hi JG,
I configured AAA Authentication & authorization in firewall but it works only for local username/password. PIX version 7.2(2) and ACS-SE 4.1.
Following is my configuration
XXX-PIX515(config)# sh run aaa-server
aaa-server VPN protocol radius
accounting-mode simultaneous
aaa-server VPN host
key XXXX
aaa-server VPN host
key XXXX
aaa-server my-group protocol tacacs+
aaa-server my-group host
key XXX
aaa authentication telnet console my-group LOCAL
aaa authentication enable console my-group LOCAL
aaa authorization command my-group LOCAL
aaa accounting command privilege 15 my-group
Note: Also I have RADIUS as same ACS for my VPN access and I add it as RADIUS client with different key. Moreover I could not see any failed logs on ACS. It works fine with local authorization.
Can you tell me why I cant authenticate and authorize with TACACS+ server.
Thanks in advance
