remote access vpn issues
Mar 7th, 2008
Hi all, I have been having issues with my remote access vpn, I can connect but cannot ping anywhere, I have enabled ipsec over nat-t, but still does not work, I noticed that when I did an ipconfig on my machine, I get the ip address assigned by my asa, 10.120.50.2 /32
but the default gateway is showing as 10.112.50.3, is this correct, I thought it should be the same as the interface address ?
brettmilborrow Mon, 03/10/2008 - 02:02
Hi Carl,
Can you make sure you have the following in your config:
isakmp nat-traversal
Can you also ensure your internal network has routing in place to cover your VPN client pool.
