change the password for controller based Access Points on the WCS
sabhasin Mon, 03/10/2008 - 21:18
this will be available in WCS release 5.1.x.x (under "configure - controller templates - system")
krengasw Tue, 04/01/2008 - 08:20
  • Cisco Employee,
global username and password can be changed via:wcs.this feature was supported on wcs:5.0.56.0.
1)click configure>(click link under name of any controller>system>AP username and password.
2)give AP username and password .
3)give enable username and password.
4)click save.
now try to login to any of your AP using this username and password.ANY future AP joining controller will use this username and password.
if you want particular AP username and password to be changed.then
1) click AP.CLICK link under ap name.
2)enable check box over ride global username and password.
3) give username and password
4)give AP enable username and password.
5)click save.
Trending Topics - Security & Network
