Maximum Virtual-Access interfaces
I am searching for a platform that allows for concurrent 10'000 PPP connections to Virtual-Access interfaces. I have searched CCO quite some time but I have not found any document that helps me. I assume that the 2811 is limited to 1382 because thats the highest number that you can pre-clone.
If somebody can direct me to a document that helps to compare ISR, 7200, 7300 and maybe ASR that would be very helpful.
Mat
Not applicable
The limt of Virtual access interface is determined by the 'interface description block,.the amount of which is hardcoded in the ios.
You can refer this link for more information:
http://www.cisco.com/warp/public/63/idb_limit.html
Cool answer, thanks. I have found the 7200/7300 and the ASR1000 in the meantime that solve my problem.
Mat
