FWSM config(Active/Stanby)
Mar 7th, 2008
I have configured Primary FWSM failover with statelink and configured Secondary FWSM failover with same primary ip.started detecting Mate.failover is configured correctly..Then i have stated to configure normal config link nameif, ip address..its started replicating the same to Secondary FWSM..when i though of doing Failover test i have reset the Primary then gave sh fail in primary..its is showing like bellow
ABCFWSM001# sh fail
Failover Off (pseudo-Standby)
Failover unit Primary
Failover LAN Interface FWFAILOVER Vlan 99
Unit Poll frequency 1 seconds, holdtime 15 seconds
Interface Poll frequency 15 seconds
Interface Policy 50%
Monitored Interfaces 0 of 250 maximum
but Secondary is in Active state..Primary status is disabled.
Kindly advice me how to start the config(like primary normal config first and Secondary is next..then on failover)...What's the correct procedure to go..and provide me the steps for failover config also..Thanks in advance
sureshkum Fri, 03/07/2008 - 10:09
Kindly provide me information. FWSM ver 2.3(4)--Cat 6509
Jon Marshall Sat, 03/08/2008 - 07:49
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Can you post configs of both FWSM's + the part of the 6500 config that includes the firewall vlan-group xxxx bit.
What happens if you type
"failover on"
Jon
sureshkum Mon, 03/10/2008 - 02:56
Thanks for ur response.i will post the config soon.Kindly advise me how to start config for new fwsm with active/ standby mode..
