vpn tunnels
Mar 7th, 2008
Hi all, due to the limitations of a partner companies firewall, they had to create 2 seperate tunnels to my asa to support 2 different source networks, on my end I just used the one tunnel to connect to the 2 tunnels on the other side, what is this called, dynamic tunnels ?
brettmilborrow Mon, 03/10/2008 - 02:00
Hi Carl,
Are you sure that you are not confusing security associations with Tunnels?
Your VPN config is not dynamic if you are using static information to configure the tunnel (IP address etc).
What type of device is on the remote site?
