Viewing parked calls from phone
Mar 7th, 2008
We are using a UC520 in PBX mode. We are looking for a better way to monitor calls that are placed in park. Ideally we would like to bring up a list of calls on park from the screens of one of our 7970 phones. Is this possible? If not, what other options do we have?
Rgss,
Diego
Overall Rating: 3.7 (3 ratings)
Paolo Bevilacqua Fri, 03/07/2008 - 06:34
  • Hall of Fame,
    Founding Member
Sorry, that is not possible. You can configure the various options in the park-slot commands to make so parked calls do return to certain extensions or alternate extension after a timeout.
Rob Huffman Fri, 03/07/2008 - 06:42
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Diego,
You can't do this from the screen of the 7970 , but you can Monitor the Call Park slots using Line Buttons. If you are using alot of Call Park slots you may need to add a 7914 Sidecar to Monitor all of them;
In Cisco CME 3.2.1 and later releases, call-park slots can also be monitored. If a call-park slot is assigned to a monitor button using the button m command, the line status shows "in use" when a call is parked in the monitored slot. A call that is parked on the monitored call-park slot can be picked up by pressing the assigned monitor button.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmepark.html#wp1010677
Hope this helps!
Rob
Paolo Bevilacqua Fri, 03/07/2008 - 06:47
  • Hall of Fame,
    Founding Member
Right, right Rob!
Paolo Bevilacqua Fri, 03/07/2008 - 09:01
  • Hall of Fame,
    Founding Member
Sorry, CME has no documented API to interact with parked calls.
DIEGO ALONSO Fri, 03/07/2008 - 09:19
I guess they have to leave some stuff out or otherwise nobody would buy Call Manager. ;)
Diego
