Mar 7th, 2008
Hey everyone --
I have a customer with 15+ branches running in SRST mode. About half of the branches have a VPN tunnel through the internet, the other half are on directly on the MPLS (via a T1 or DSL/Net-VPN). I have a problem where each of the branches will randomly go into SRST mode, even though there is no evidence that the tunnel went down.
My keepalive on the gateway is set to 20 seconds, but the phones will take about 2 minutes to re-register with the CCM. This I can probably fix eventually, but I wanted to know if anyone else is running a gateway with SRST over a VPN to see if I need to modify my settings to prevent the site from entering SRST at all.
Thanks guys.
Overall Rating: 1 (1 ratings)
hadbou Thu, 03/13/2008 - 07:23
There are different ways to display the RTP packets sent and received by the ephone. You can determine whether the ephone can receive RTP packets from Cisco CallManager Express in these ways:
Issue the show ephone command on Cisco CallManager Express.
Browse the ephone ip address in order to check the call stream statistics.
Press the help (i or ?) button twice in quick succession during an active call in order to show the call statistics on the screen.
Normally, GRE over IPSec is the recommended solution for this one-way voice issue. If the remote VPN client cannot support the GRE tunnel, as is the case with VPN 3002 client software, you can still use policy routing to achieve two-way audio.
You can use Policy-based Routing (PBR) in order to force the ephone traffic through the encryptor. In order to do this, apply a static route to the remote ephone pointing at a loopback interface. Then use PBR on the loopback in order to set the next hop downstream of the crypto map.
This is a sample configuration:
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group RemoteUsers
key emmanuel
crypto isakmp client configuration group cisco
key cisco
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map SDM_DYNMAP_1 1
set transform-set ESP-3DES-SHA
crypto map SDM_CMAP_1 client authentication list sdm_vpn_xauth_ml_1
crypto map SDM_CMAP_1 isakmp authorization list sdm_vpn_group_ml_1
crypto map SDM_CMAP_1 65535 ipsec-isakmp dynamic SDM_DYNMAP_1 !
!--- Create the loopback interface and apply the policy
interface Loopback10
ip address
ip policy route-map 10
interface GigabitEthernet0/0
ip address
duplex auto
speed 100
interface Service-Engine0/1
ip unnumbered GigabitEthernet0/0
service-module ip address
service-module ip default-gateway
interface GigabitEthernet0/1
ip address
duplex auto
speed auto
no keepalive
ip classless
ip route
!--- Route the ephone traffic to the loopback interface.
ip route loopback10
ip route Service-Engine0/1
ip http server
no ip http secure-server
ip http path flash:
!--- Define the access-list to match the traffic to ephone.
access-list 101 permit ip any host
!--- Configure the route-map for the policy routing and
issue the set ip next-hop or set interface command in the route-map
in order to force the ephone traffic to go through the encryptor.
route-map 10 permit 10
match ip address 101
set ip next-hop
ouhakheme Thu, 03/13/2008 - 09:36
I'm not using CCME.
I'm also not having any issues with one-way voice. My phones are working without issue; however, they unregister periodically.
