paolo bevilacqua Fri, 03/07/2008 - 07:15
  • Hall of Fame,
    Founding Member
Do you have PRI, and do you have callamanager, or what ?
t.sriwetchasin Fri, 03/07/2008 - 07:29
I have PRI and also have CCM. I want to translate PSTN no. to internal extension no.
Example. PSTN no. xx-xxx-xxxx translate to internal extension no. yyyy
How to config in voice gateway router, or setting in CCM is more flexible ?
t.sriwetchasin Fri, 03/07/2008 - 07:39
My system is C3845 with VWIC2-1MFT-T1/E1 IOS 12.4 and 4FXS-DID CCM 6.0
paolo bevilacqua Fri, 03/07/2008 - 07:47
  • Hall of Fame,
    Founding Member
If you use mgcp, all the config is in the ccm.
If using h.323 or sip, you can config in router, ccm, or both.
t.sriwetchasin Fri, 03/07/2008 - 08:42
If I used h.323, I need to create translation rule into gateway router for DID or any other solution ?
thank you.
paolo bevilacqua Fri, 03/07/2008 - 08:50
  • Hall of Fame,
    Founding Member
As mentioned above, you can have the translation done either the router, or in the ccm. Really it depends on what you like better to configure.
descalante2007 Wed, 04/09/2008 - 14:07
I'm in a similar problem. I have CCME running on a C2851 with a VWIC-1MFT-G703. The Telco is providing 30 DID numbers through an E1 connection. (58500800 to 58500829)
At this time all calls are ringing to operator because I set a "connection plar" command in the voice-port 0/0/0:1 which is the VWIC card.
I understand I should define DID numbers as secondary numbers in the corresponding ephone-dn's. I tried but unsucessfully. So, I guess I'm missing something.
Thanks in advance
paolo bevilacqua Wed, 04/09/2008 - 14:15
  • Hall of Fame,
    Founding Member
No is not said that you have to create secondary numbers.
You can also use dialplan-pattern under telephony-service.
The syntax of the command really depends on how you configured the extensions numbers.
Another alternative is translation-profile and rule under voice-port.
