Cisco VPN Client Vista 64-bit x86
Mar 7th, 2008
  • Bronze, 100 points or more
Cusotmer is migrating to new laptops with Vista Business Edition 64-bit (x86).
Old laptops ran XP Cisco VPN Client 32-bit.
Is there a 64-bit version of the Cisco VPN Client for Vista?
didyap Thu, 03/13/2008 - 07:30
  • Silver, 250 points or more
There is no VPN client for Vista 64 bit, however if you are using ASA Version 8.x you can use ANY CONNECT. ANY CONNECT will work only with ASA code 8.x and above and no other device support it as of now.
Phillip Remaker Fri, 02/19/2010 - 11:32
  • Cisco Employee,
February 18, 2010
Due to popular demand, the Cisco VPN Client v5.0.7 open beta is now available!
In addition to serving as a general maintenance release, the Cisco VPN Client 5.0.7 beta is compatible with Windows 7 & Windows Vista 64-bit environments.
A 64-bit specific compatible image is available for installation on these platforms.
Please have communicate feedback (both positive and problems) to [email protected].
Key Capabilities available for Beta Testing:
New Platform support – Windows 7 & Windows Vista 64-bit platform compatibility
Software Access: http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=281940730 (under 5.BETA)
Software is available for download by any customer with a Cisco.com SMARTnet™ enabled login.
Release Notes will be available next week via a link once the download image is selected.
