available resource during ccie r&s lab
Answered Question
Mar 7th, 2008
I understand reading from previous threads that during ccie lab, a tester have access to univercd but search feature is disabled.
http://www.cisco.com/univercd/home/home.htm
my question is, from the univercd url, can you jump to "cisco.com>technologies" which is found below the url.
my question is leading to the ability to access, "config guides" available under each technology.
just curious :>
Correct Answer by Edison Ortiz about 8 years 11 months ago
You can't jump to any page outside the univercd.
I suggest using the univercd only for quick command lookup and verification.
If you are planning to follow a 'config guide' you are going to waste a lot of precious time.
__
Edison.
Overall Rating: 5 (1 ratings)
Correct Answer
Edison Ortiz Sat, 03/08/2008 - 14:21
__
Edison.
