ciscoworks 2.6
Mar 7th, 2008
  • Bronze, 100 points or more
I have finally rebuilt my box with all the current 2.6 stuff on it. I have two pieces of equipment that constantly fail in the inventory update process. The error the job reports is "device sensed but collection failed" for the inventory collection routine. If I go to Device manager and choose the device and do an inventory update I get the same error.
I have tested credentials and they report back as being okay. I can use the Device manager to telnet, view the config, pretty much anything but inventory. Thoughts on what to try to get rid of this error? thanks.
Joe Clarke Fri, 03/07/2008 - 11:05
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
There are known bugs with the inventory collection process. What version of RME do you have? If you look in the IC_Server.log, what errors do you see relating to these devices?
