ATA 186
goldbergj Fri, 03/07/2008 - 19:48
what exactly are you wanting to plug into the ATA? An analog phone? If so, what is it plugged into now, an FXS card on the voice gateway router?
thanks,
JG
Daniele Giordano Thu, 03/20/2008 - 01:14
  • Gold, 750 points or more
Yes, ATA stands for "analog telephony adapter".
From CISCO ATA guide:
• Two RJ-11 FXS (Foreign Exchange Station) ports-The Cisco ATA supports two independent
RJ-11 telephone ports that can connect to any standard analog telephone device. Each port supports
either voice calls or fax sessions, and both ports can be used simultaneously.
Note The Cisco ATA186-I1 and Cisco ATA188-I1 provide 600-ohm resistive impedance. The
Cisco ATA 186-I2 and Cisco ATA188-I2 provide 270 ohm + 750 ohm // 150-nF complex impedance.
The impedance option is requested when you place your order and should match your specific
application. If you are not sure of the applicable configuration, check your country or regional telephone
impedance requirements.
