03-07-2008 12:11 PM - edited 03-05-2019 09:37 PM
How do I remove auto from an interface? I have a port that is set to switchport mode dynamic desirable. When I try to set the interface to swicthport mode trunk I get command rejected. An interface whose trunk encapsulation is "Auto" can not be configured to "trunk" mode.
DJ
03-07-2008 12:22 PM
Hi Donna,
You should select an encapsulation protocol first, dot1q or isl.
switchport trunk encapsulation [dot1q | isl]
switchport mode trunk
Cheers:
Istvan
03-10-2008 08:20 AM
Thanks! Worked great. I would check out as solved my problem, but it didn't give me the option.
DJ
03-10-2008 10:41 AM
You're welcome Donna!
Cheers:
Istvan
