Restrict Access to VLAN
I am trying to restrict traffic into a vlan on a 3750. I only want to allow access from specific IP addresses and drop everything else. I setup the following ACL and vlan map configs on the 3750.
ip access-list extended QA_VLAN_ACL
permit ip host 10.3.10.77 any
permit tcp host 10.3.10.77 any
permit tcp host 10.3.10.35 any
permit tcp host 10.3.10.36 any
permit tcp host 10.3.10.37 any
permit tcp host 10.3.10.38 any
permit tcp host 10.3.10.39 any
permit tcp host 10.3.10.40 any
permit tcp host 10.3.10.41 any
permit tcp host 10.3.10.42 any
permit tcp host 10.3.10.43 any
permit tcp host 10.3.10.44 any
permit udp host 10.3.10.35 any
permit udp host 10.3.10.36 any
permit udp host 10.3.10.37 any
permit udp host 10.3.10.38 any
permit udp host 10.3.10.39 any
permit udp host 10.3.10.40 any
permit udp host 10.3.10.41 any
permit udp host 10.3.10.42 any
permit udp host 10.3.10.43 any
permit udp host 10.3.10.44 any
permit udp host 10.3.10.77 any
vlan access-map QA_VLAN_MAP 10
action forward
match ip address QA_VLAN_ACL
vlan filter QA_VLAN_MAP vlan-list 325
However, it doesn't seem to work. If I have the action set to forward than everything gets through and nothing is dropped. If I set the action to drop everything is dropped. I am not sure what I am doing wrong. Any help that can be provided will be much appreciated. Thanks.
Edison Ortiz Sat, 03/08/2008 - 10:02
  • Hall of Fame,
    Founding Member
Hi Ernest,
VLAN maps have no direction. To filter traffic in a specific direction by using a VLAN map, you need to include an ACL with specific source or destination addresses.
If there is a match clause for that type of packet (IP or MAC) in the VLAN map, the default action is to drop the packet if the packet does not match any of the entries within the map.
If there is no match clause for that type of packet, the default is to forward the packet.
Can you add deny ip any any at the end of the ACL and see if the behavior changes?
HTH,
__
Edison.
Edison Ortiz Sun, 03/09/2008 - 11:41
  • Hall of Fame,
    Founding Member
Please post the whole config.
__
Edison.
Edison Ortiz Sun, 03/09/2008 - 12:08
  • Hall of Fame,
    Founding Member
Try this approach:
action forward
vlan access-map QA_VLAN_MAP 20
match ip address QA_VLAN_ACL_DROP
action drop
ip access-list extended QA_VLAN_ACL_DROP
permit ip any any
HTH,
__
Edison.
Edison Ortiz Tue, 03/11/2008 - 11:59
  • Hall of Fame,
    Founding Member
The ACL is affecting devices on Vlan 310 (Subnet 10.3.10.x) therefore the vlan-list should be applied to 310 not 325.
__
Edison.
joshkurtz Tue, 03/11/2008 - 10:59
I am having the same problem, I am using a 3560 and whenever I try to drop a subnet everything is dropped.
