V12.4 no service-module command or serial interfacd
Mar 7th, 2008
I have new 2851 with 12.4. I installed a vwic 2mft-t/e1 card but can't configure. I don't have the service-module command of a serial interface, what am i mssing?
Richard Burts Fri, 03/07/2008 - 14:16
Some of the documentation that I have looked at describes beginning by configuring controller e1 slot/port. Have you done the controller configuration? That may be required to see the serial interfaces (especially on a card that can do both voice application as well as data application)?
b-ulrich Fri, 03/07/2008 - 14:22
Your probably going to need the command:
'card type t1 0 0' The 0 0 depends on what slot you have the card installed in I believe.
The the controller config will then show up.
