Display Original Calling Number on Transfer from IVR
Mar 7th, 2008
I need to display ani number after transfer from AA on ivr to traditional
without sopport QSIG(IE). actually the transfer is using only the source cti port number not passing the original calling number. this is working only on transfer to ip phones not digital phones behind the pbx via e1 isdn
how can make it?
bwilmoth Fri, 03/14/2008 - 07:01
If the call is in the queue still, there is no way that agents get the information in CAD. If, what you want, is to get the called number when the call is already at an agent
sdeltoro1 Mon, 03/24/2008 - 09:28
isnt about agent, the need to get the original calling number is because the autoattendant is on ivr and the call will be transfer to digital extension.
lbjr Thu, 02/04/2010 - 11:34
I know this post is two years old, but did you ever get a resolution, I am having a similar issue with PRI to Autoattendant then XFER over QSIG to CCM, Cisco phones don't show ANI of orignal ISDN Caller.
sdeltoro1 Tue, 02/09/2010 - 09:17
the Customer has a Unity too. soo I move the AA on unity and the call.manaer after 6.x has a service parameter: Display Original Calling Number on Transfer from Cisco Unity  . Now the original number is shown
a11anwr1ght Sun, 12/05/2010 - 01:42
Not sure if you are using ICM in this, but before the call is sent to the IVR (like the first script the call goes to) use the set variable node to assign the CLID of the caller to call variable1 or 2 or X, you could even do that for the customer's dialed number as well.  That way it will show up on CAD.
