PIMG issue for connecting CUC and Nortel PBX, need help
Mar 7th, 2008
We use 8 ports UNITY-PIMG-DIG to connect a Nortel PBX and Cisco Unity connection. Once it works fine. Now we meet a problem. The first two ports of the PIMG can not pick up the call and transfer it to the Unity correctly. It makes Nortel PBX identify this as a failed call and transfer it to the Nortel attendant. I make a simple test, when I connected the line once was plug in the first two ports of PIMG to a standard Nortel phone, it rings correctly.
I traced both of the call, here is the log.
(1) When connect the line to PIMG
.trac 12 1 4 1
TN 012 1 04 01
KEY 0 SCR MARP ACTIVE TN 012 1 04 01 DIRECT MW_CALL
ORIG 012 1 04 01 0 SCR MARP 0 7569 2616
TERM 000 0 12 15 0 SCR MARP 0 6714 2616
DIAL DN NONE
MAIN_PM ESTD
TALKSLOT ORIG 94 TERM 30
QUEU NONE
CALL ID 0 6541
(2) When connect the line to a phone
.trac 12 1 4 1
TN 012 1 04 01
TERM DN 6714
TDTN 16 SLOT 15 PTY SLOT 79
DIAL DN 6714
MAIN_PM RING AUX_PM
TALKSLOT ORIG 81 TERM 17 JUNCTOR ORIG0 TERM0
QUEU CAD
CALL ID 0 7125
