PIX 515E
Answered Question
Mar 7th, 2008
hi,
I just want to check if this is possible.
PIX 515E running 6.3
I want certain internal networks to
use a different PAT global address.
192.168.1.0 ---- > PAT to 203.115.155.1
192.168.2.0 -----> PAT to 203.115.155.2
so in this case anything coming from 192.168.1.0 will be translated to 203.115.155.1 on the outside interface
anything coming 192.168.2.0 will be translated to 203.115.155.2 on the
outside interface.
Correct Answer by sundar.palaniappan about 9 years 3 months ago
Sure, use a different NAT ID to group them to the corresponding global (PAT) address.
nat (inside) 1 192.168.1.0 255.255.255.0
nat (inside) 2 192.168.2.0 255.255.255.0
global (outside) 1 203.115.155.1
global (outside) 2 203.115.155.2
Sundar
Overall Rating: 5 (1 ratings)
Correct Answer
sundar.palaniappan Fri, 03/07/2008 - 17:08
  • Green, 3000 points or more
Sundar
