CME + Pitney Bowes = no goes
Mar 7th, 2008
2811 12.4(15)T1
CME 4.2
Multi Flex T1 v2
NM-HDA-4FXS
I've seen one post on here about a Pitney Bowes postage scale, Call Manager, and FXS ports. My setup is somewhat the same, except the customer has a T1 delivering 17 loopstart channels.
The other topic somewhat strayed away from the subject.. has anyone else had experience with this? The T1 is error free, and faxes are working properly, however the postage scale cuts off halfway through negotiation.
I haven't tried lowering the baud rate on the PB scale yet maybe that will be my next step. I didn't do much on the router side either though except for turning off comfort noise on the fxs port. Would the rate disabling under 'voice service pots' have any affect? Thanks in advance.
paolo bevilacqua Sat, 03/08/2008 - 05:14
  • Hall of Fame,
    Founding Member
Hi, can you send complete output of "show controllers T1" ?
allenelson Sat, 03/08/2008 - 09:13
The intervals are too long to post.
T1 0/0/0 is up.
Applique type is Channelized T1
Cablelength is long gain36 0db
No alarms detected.
alarm-trigger is not set
Soaking time: 3, Clearance time: 10
AIS State:Clear LOS State:Clear LOF State:Clear
Version info Firmware: 20070320, FPGA: 20, spm_count = 0
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (544 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Data in Interval 94:
Data in Interval 95:
Data in Interval 96:
Total Data (last 24 hours)
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
paolo bevilacqua Sat, 03/08/2008 - 09:44
  • Hall of Fame,
    Founding Member
You are right, squeaky clean T1.
You can try adjusting the levels a bit on the fxs ports, but I'm not sure it will help.
allenelson Mon, 03/10/2008 - 06:55
anyone else have any input on the subject? it sounds like the baud rate needs to be lowered on the machine.. but any other ideas are appreciated.
ROBBY HARRELL Fri, 04/25/2008 - 13:48
I ran into a similar problem with a PB machine at an University Mailroom working off a VG248. Faxes worked fine, but the PB modem would not establish connection. The solution was to drop the output levels on the VG248 port (output attenuation, around 6 or 9 db).
The audio signal was to strong for the modem, since it was only about 50 ft of copper wire between the VG 248, and the PB machine.
