ACS database
Mar 7th, 2008
I have ACS and is running with windows database integration. But i have some issue the users are created in active directory and then acs ask if the user exists and then it hold the users mappings in his own database (normal operation) but the question is when i delete users from active directory the users still in acs and they can still authenticate i have to block the user in acs or delete manually the mappings is there some procedure that when i delete the user in active directory i do not have to delete the user in acs too?
