Can I use voip to tunnel a voice T1 over an IP network?
Mar 7th, 2008
We have two analog phone switches currently connected together via a point to point private T1 line. I would like to replace the T1 between the switches with a pair of Cisco routers and IP network connection (we have plenty of bandwidth for it). What Cisco hardware would I need and what would the configuration look like? Thanks!
Overall Rating: 4 (1 ratings)
dknov Sat, 03/08/2008 - 17:53
Two methods I am aware of for this case:
1. Circuit Emulation over IP (CEoIP)
Example: http://www.cisco.com/en/US/prod/collateral/routers/ps282/product_data_sheet09186a00802045f5_ps5854_Products_Data_Sheet.html
2. Transparent CCS (T-CCS)
Example:
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800a96c1.shtml#tccsmatrix
T-CCS is a more legacy one, but I have used it a few years back to interconnect two Avaya PBXes over WAN circuit.
HTH.
David
Paolo Bevilacqua Sun, 03/09/2008 - 07:39
Can I add something to the advice above. These methods are generally used for when the PBX protocols as so proprietary that regular VoIP doesn't work.
In 99.9% of the cases, you do a regular voip configuration that has many advantages over TCCS or CES, and everything works perfectly.
