no login prompt after dialup connectivity through PSTN
eash
Dear All,
The router's AUX port is configured as follows
line aux 0
exec-timeout 5 0
logging synchronous
login local
modem InOut
exec prompt timestamp
transport input all
flowcontrol hardware
An external dialup modem is connected to the AUX port of the router and modem is configured for Auto answer.
When i connect to the router through a PSTN dialup I dont get login propmt.
Please see the capture.
I have tested the modem by connecting to another router. The PSTN connected to the modem is fine since I get hand shake tone and can see connect at 9600 baud but dont get the login prompt.
what could be problem.
Easwar
5 Replies 5
jbayuka
Level 5
Level 5
Your router does not have an enable secret password, so incoming connections will not be able to enter the enable mode.
For more information please click following URL:
http://www.cisco.com/warp/public/471/mod-aux-exec.html
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_tech_note09186a008009428b.shtml
thanks for your replies...
But after logging into the router I found that the aux line is always active even after resetting the modem what could be problem (the show line capture is as below)
router#sh line
Load for five secs: 6%/0%; one minute: 2%; five minutes: 2% Time source is NTP, 11:56:20.785 UTC Wed Mar 19 2008
Tty Line Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
0 0 CTY - - - - - 0 0 0/0 -
* 1 1 AUX 9600/9600 - inout - - - 1 0 7/0 -
* 194 194 VTY - - - - 1 64 0 0/0 -
195 195 VTY - - - - 1 2 0 0/0 -
196 196 VTY - - - - 1 1 0 0/0 -
197 197 VTY - - - - 1 0 0 0/0 -
198 198 VTY - - - - 1 0 0 0/0 -
199 199 VTY - - - - 1 0 0 0/0 -
200 200 VTY - - - - 1 0 0 0/0 -
201 201 VTY - - - - 1 0 0 0/0 -
202 202 VTY - - - - 1 0 0 0/0 -
203 203 VTY - - - - 1 0 0 0/0 -
Line(s) not in async mode -or- with no hardware support:
2-193
Easwar
Danilo Dy
Makarand Chitale
Please try using "autoselect during-login" under line aux 0.
ubr10k2#conf t
Enter configuration commands, one per line. End with CNTL/Z.
ubr10k2(config)#line aux 0
ubr10k2(config-line)#autos
ubr10k2(config-line)#autoselect ?
arap Set line to allow ARAP autoselection
during-login Do autoselect at the Username/Password prompt
ppp Set line to allow PPP autoselection
slip Set line to allow SLIP autoselection
timeout Set wait timeout for initial autoselect byte
Thanks, Mak
Dear All,
Please find the capture of sh line and sh line 1 we can see that the modem inout is clearly shown. But in sh line 1 we can see that the modem hardware state is showing CSR* DSR* DTR RTS.
I am not getting router login prompt. I can see the modem ring and handshake.
Any suggestion how to resolve this issue.
Easwar
